AEG F35020VI (91153904302) Dishwasher Problem
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries AEG F35020VI (91153904302) Dishwasher Problem
  • #86710
    jontymox
    Good evening,
    I’m wondering if anyone can help with a problem on the above dishwasher?
    The appliance has activated the anti-flood device, although upon inspection there is no leak.
    I’ve tried re-setting the programmes, tested the float micro switch, which is fine and I’m unsure as to how to conclusively test the aqua stop hose.
    I’m wondering if I could temporarily connect a standard hose, bearing in mind the aqua stop has a wiring connection to the above micro switch, which needs to communicate with the control module??
    A wiring diagram would be appreciated, if available.
    jonty
    #432827
    jontymox
    Re: AEG F35020VI (91153904302) Dishwasher Problem
    p.s.
    I failed to mention that I’ve checked both pressure switches, and pipework which are fine, so I don’t think the control module is receiving false values.
    #432828
    jontymox
    Good afternoon,
    Pleased to report that it was a faulty aqua stop.(solenoid jammed?)
    Renewed above, and all well.
    jonty
