Looking for a bit of help here.Not found anything on search and my TDS has decided not to work.
This dishwasher exhibits all the signs of a flooded base, ie drain pump whirring away all the time. However, there is no water in the base and the float switch is definitely not made. The “end” light flashes 3 times, pause then repeats. Anybody know what this means?
Thanks for that Colin. I did disconnect the tube to the pressure switch and blow down it.All seemed clear. Gently blew into switch as well and got an audible click.
