Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › AEG F65040iM0P Heating Element Location
- This topic has 9 replies, 3 voices, and was last updated 4 years, 9 months ago by
andy_48.
June 29, 2021 at 8:33 am #99733
andy_48
ParticipantAEG F65040iM0P PNC 911 424 303
Runs fine but not heating the water, so I suspect the heating element.
Got the thing apart this morning but can’t for the life of me find the heating element!
I’d be really grateful for any pointers (and any tips on removing it) to save my sanity.June 29, 2021 at 8:50 am #477670electrofix
Moderatorits the front end of the wash motor
there are 3 types so dont assume this is yours
https://shop.ukwhitegoods.co.uk/4055373700-dishwasher-heater-assemblyDave
June 29, 2021 at 9:50 am #477671andy_48
ParticipantBrilliant, thanks Dave.
I’ve got it off and mine does look exactly like that.
Like a prize idiot I’ve quoted the wrong model number – it should be F65610IM0P – so that is the correct part.
Thanks again
June 30, 2021 at 9:14 pm #477672andyjawa
ParticipantJust go on to AEG`S own spares site. Type in the product code in full begins with a 9. Find the electrical odd and sods where you will discover a model number to match your machine to check, part location drawings part number and prices.
July 2, 2021 at 9:19 am #477673andy_48
ParticipantOK. I changed the heating element and put it back together. Fiddly but seemed successful.
Now, when I start the dishwasher, the outlet pump does its initial run and when it’s done its bit I get the alarm code “i30 – The anti-flood device is on”. It’s clearly not leaking so I took off the polystyrene float just in case it was sticking but I’m still getting i30.
What should I look at next, please?
July 2, 2021 at 12:09 pm #477674electrofix
Moderatormanual says
see belowDave
July 2, 2021 at 2:05 pm #477675andy_48
ParticipantMany thanks. I’ll start investigating!
July 2, 2021 at 4:40 pm #477676andy_48
ParticipantI took it apart and put it back together again and it now seems to be running OK – now with HOT water! Definitely the heating element needed changing and probably the anti-flood sensor not quite sitting properly the first time I reassembled it.
Anyway, thanks to Dave & Andyjawa for your very valuable help.
Andy
July 2, 2021 at 7:39 pm #477677andy_48
ParticipantInterestingly, I subsequently discovered a small fatberg almost completely blocking (but not quite) the outside drain into which the DW drains the waste water. I’m no expert but I suspect this would also cause the i30 error in the “Drainage problem” category.
July 2, 2021 at 7:50 pm #477678electrofix
Moderatorandy_48 wrote:Interestingly, I subsequently discovered a small fatberg almost completely blocking (but not quite) the outside drain into which the DW drains the waste water. I’m no expert but I suspect this would also cause the i30 error in the “Drainage problem” category.
only if it leaked underneath as i20 codes are drain problems
