91123525500
Integrated dishwasher which when it fills water is dripping from the water matrix which is on the left side of the machine. (As you look from the front.)
I took the water matrix off and sealed where it pushes into the stainless steel tank.
It unfortunately is still leaking as it fills. Just a touch but enough over half a dozen washes to activate the float switch in the base.
Could it be leaking from the vent part of this water matrix?
Is this a known fault or at least could someone give me the part number for the matrix?
The clamp on the hose which goes from the water matrix to the sump is rusty so this would indicate a small leak for some time.
Thanks.
