Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › AEG F86050VI -PNC 91123472602
- This topic has 2 replies, 2 voices, and was last updated 8 years, 8 months ago by
WhiteVanMan1.
July 22, 2017 at 6:32 pm #91741
WhiteVanMan1
ParticipantDo you ever get those weeks from hell? Where everything seems to be against you, and nothing makes sense? Such has been my week :-).
I went to this dishwasher and found that the dosing tank was blocked up, and the base was filling with water. Simple I thought. Order a new tank. So I ordered part no 4071349759 as listed on the Zanussi website, through Maddocks. I duly went back and fitted it and expected it to work perfectly, just like every other one I have ever done.But no. As soon as it began to fill, there was a leak from behind it, from a small plastic flap that is covering a couple of holes, then the overflow started to fill up the base again. I took the tank back off twice to double check I had not done owt daft, but all is as it should be. At this point, with brain ache and a complete lack of belief in the laws of physics, I gave up. The flow to the sump is clear, and as there is basically just one way in, and one way out for the water to flow, (apart from the water softener unit), I have come to the conclusion that the tank must be faulty. The problem with this is that although parts can be faulty on arrival, it is rare. But then this part is pressed and sealed at the seams, and I imagine could quite easily be assembled incorrectly. Any ideas please? Any assistance would be much appreciated. Cheers. Steve.July 22, 2017 at 7:53 pm #449105electrofix
ModeratorRe: AEG F86050VI -PNC 91123472602
got to be a blockage somewhere. assume its not overfilling
so its either the new part faulty in some way or a blockage further on
did find a tech bulletin for this part but it must be for an earlier version as it talking about fitting the flap and sealing everything with silicone
the flap is described as a ventilation damper to prevent overpressure
July 22, 2017 at 9:30 pm #449106WhiteVanMan1
ParticipantRe: AEG F86050VI -PNC 91123472602
Cheers Dave. No it isn’t overfilling. It begins to leak straight away. If I divert the leak away, it fills up and away it goes beautifully. Until the next time it fills. I am of the opinion that the fault has to be in the new part. There is definitely no blockage in the sump, and I don’t think the softener unit will be the culprit. I really just needed a second opinion. I am always dubious about blaming new parts, though over the years I have had my fair share. It looks as if I will be ringing Maddocks first thing on monday morning. Thank you for your help and I will keep you posted. Steve.
