AEG F89020VI
  • #88167
    WhiteVanMan1
    Customer complained of no heat. I have checked the heater which is ok, and the pressure switches check out ok. The board looks ok, but that is all I can come up with having checked all else out. Does anyone know of board failures on this dishwasher? Cheers. Steve.
    #437214
    Re: AEG F89020VI
    just to make things difficult there are 18 models with the same model number .
    could be NTC or have you checked heater relay on the board
    WhiteVanMan1
    Re: AEG F89020VI
    Yes Dave, I have checked the heater relay visually, and it is ok. The NTC is a type I haven’t seen before, but it could be switching early I suppose. The price of the board makes the NTC an avenue worth taking. Thank you for your reply. I’ll let you know how it goes. Cheers. Steve,
    #437216
    Re: AEG F89020VI
    the relay is a mechanical device and prone to failure. the only way to be certain its working is to look for the coil voltage
    if you want some tech info let me know product code
    WhiteVanMan1
    Re: AEG F89020VI
    Hey up Dave. Yes, I checked the relay for dry joints but any info is useful ta. I will pm you my email address. cheers. Steve.
