Hello
I’ve an AEG D98000VF cooker, the fan oven element is not working, I’ve checked the element it is fine (27ohms),it seems to be switched from a relay on the main PCB, is it likely to be a fault with the relay/PCB or is there anything else?
The conventional element in the same oven is working fine, these both go through the safety thermostat.
