AEG fault code ?
  • #37484
    AEG washer dryer model L16820 (914602104)
    the fault is it starts to fill, drum rotates the E30 appears
    not listed on Pro Corner ?
    any ideas please
    Simon
    #255273
    Re: AEG fault code ?
    E30 group faults relate to water level issues.
    trickydickyd
    Check none of the wires have came of the heating element. This can cause a E33 fault. If the wire is off take out element, inspect for scuff marks, Megger it and if it’s ok put it back in making sure it is slid into the element clip attached to the inner tub. There was a batch of these went out where the elements were not slid into element clip. the element would rattle against the drum on spin and cause the wires to jump off the element
