AEG fault code CE ?
  • #11507
    Sorry don’t have full model number, just taken a call from a customer with a german made AEG with error code CE ( water distibution fault)
    apparently fairly common, how easy is this to cure and what are the parts/costs involved ?
    #145586
    Dave_Conway
    Re: AEG fault code CE ?
    It’s the water distributor thing, basically the top of the dispenser which has a motorised water direction thing on it.
    There are two or three types so PNC required to identify the correct one πŸ™‚
    #145587
    Thanks, will get back to her. πŸ™‚
    #145588
    PNC is 914001 33100
    According to TDS disc I need an, 899645 4307-0814, is that correct and what is the price of same?
    Also, how easy/difficult is this to change. πŸ™‚
    #145589
    The number I know to be for that PNC is 8996454307993 πŸ™‚
    Easy to fit, the fascia panel needs removing first then it’s downhill all the way!
    #145590
    Dave_Conway
    iadom wrote:According to TDS disc I need an, 899645 4307-0814,
    There’s no such part number πŸ˜•
    8996454307993 is the one you need, it should cost you around Β£35 (Β£46.23 ex VAT is the Lux list price)
    Pretty easy, you need to remove the control panel though to allow the dispenser to move forward enough to get the top off πŸ™‚
    #145591
    Dave_Conway
    :wave:
    #145592
    Don’t know how I came up with that part number 😳
    It has been one of those days today, πŸ˜₯
    Thanks for the help.
    #145593
    Dave_Conway wrote::wave:
    :wave: We do keep tripping over each others feet don’t we Dave :rotfl:
    #145594
    You could have warned me about the two small empty plugs on the new distributors edge connectors. For one heart stopping moment I though I had the wrong part when I couldn’t get the plugs back on. 😳 πŸ˜€
    #145595
    bobokines
    I fitted one of these a few weeks ago. The twits at Connect Distribution warehouse thought it a good idea to put two cooker hinges inside the dispenser to save on packaging. It didn’t survive…
    Bob
    #145596
    iadom wrote:You could have warned me about the two small empty plugs on the new distributors edge connectors. For one heart stopping moment I though I had the wrong part when I couldn’t get the plugs back on. 😳 πŸ˜€
    :rotl: We few, we brave souls, have suffered the same heart rendering moments over the very same issue by finding those same connector blocks on the end of the board that do not compare with the connectors you have to hand πŸ˜•
    …..then in a moment of brilliant realisation πŸ’‘ (they are only stuck on the bl**y board for show I reckon)….you rip them off and plug in the existing connectors…. and away it goes πŸ˜€
    :rotfl:
    VORSPRUNG DURCH TECNIK may be one way of putting it but I think it after all is spin-off from the German engineers gutted over WW11.
    As Fritz may say to Hans : “Macht alles, das Sie kΓΆnnen, den Feind zu verwirren!”
    :rotfl: :rotfl: :rotfl:
    #145597
    The whole darned thing is a complete waste of money, a three way cold fill valve would have done the job just as well.
