Aeg fault E5H Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Aeg fault E5H This topic has 7 replies, 3 voices, and was last updated 14 years, 10 months ago by colly. Viewing 8 posts - 1 through 8 (of 8 total) Author Posts June 9, 2011 at 2:35 pm #63280 collyParticipant Hi guys Any idears on this one ? Model L16850 Pnc 914605309/00 No fill / motor action will drain only Colly June 9, 2011 at 3:13 pm #353285 CriscoldParticipant Re: Aeg fault E5H E5H – Input voltage is lower than 175V Wiring faulty; Inverter board faulty. June 10, 2011 at 7:48 am #353286 collyParticipant Re: Aeg fault E5H Hi criscold Thank you for your reply . Inverter board is that the one on the bottom of chassis ? Or the one behind main fascia board ? Colly June 14, 2011 at 7:50 pm #353287 collyParticipant Re: Aeg fault E5H Hi all Turned out to be a blasted inverter board. At £102 plus vat not sure bout replacing it . Anyone had this before ? Seems to good of a machine to break up . Colly June 15, 2011 at 7:46 am #353288 MartinParticipant Re: Aeg fault E5H colly wrote:Anyone had this before ? Oh yes! 🙁 June 15, 2011 at 8:34 pm #353289 collyParticipant Re: Aeg fault E5H Hi martin Did you attempt to repair the machine ? Colly June 16, 2011 at 7:46 am #353290 MartinParticipant Re: Aeg fault E5H colly wrote:Did you attempt to repair the machine ? Oh no! 🙁 June 17, 2011 at 9:36 am #353291 collyParticipant Re: Aeg fault E5H Well you know I may just have to be a brave man If I can find a used part . Colly Author Posts Viewing 8 posts - 1 through 8 (of 8 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
