AEG FAV35080VI not drying
Home Forums Public Support Forums Help And Support Dishwasher Help Forum AEG FAV35080VI not drying
  • #68474
    allypete
    I have an AEG Favorit 35080Vi which is not drying properly. Everything is left wet at the end of a cycle.
    1. I changed the thermostat for a new one – no difference.
    2. I removed the control board, checked for loose connections, burnt out components etc but everything looks fine.
    The heater is working OK as during a wash cycle the machine heats up. It is just the final rinse that the machine does not heat the water, so that everything remains wet.
    Any help appreciated as I don’t know what to check next.
    #371206
    captaincaveman1
    Re: AEG FAV35080VI not drying
    Most AEG models have a dryer fan which sits on the top rear left of the tub itself check that if ones fitted. Another thing is are you need to ensure you use tablets which contain rinse aid as rinse aid dosent aid the rinse as the name suggests its a chemical which is released on the final rinse which makes the water slide of the dishes more easily.
