AEG Favorit 34502VIO (911 539 114 00)
Home Forums Public Support Forums Help And Support Dishwasher Help Forum AEG Favorit 34502VIO (911 539 114 00)
  • #83541
    RussJH
    Seem to have an intermittent problem with this, since Xmas Day, when the machine stopped with a 3 beep error. I took it out and tipped it 45 degrees assuming the antiflood had activated. Machine then worked fine for a couple of days. I didn’t check bottom tray.
    Now, the machine drains the water fine, pump stops, and you expect the fill to start. Slight pause, no fill and then back to drain cycle. This repeats until machine stops with a two beep error code.
    Anti-flood hasn’t tripped as I have now removed cover and can see bottom tray.
    Sometimes it will fill with water and run OK , until the next drain/fill cycle then same problem occurs.
    Drain hose is clear, water supply OK.
    Any ideas ?
    Many thanks in advance
    #423046
    bazza500
    Re: AEG Favorit 34502VIO (911 539 114 00)
    Gunge in the pressure switch.
    Remove it, clean it out, and refit.
    #423047
    RussJH
    Not sure how to locate the switch ?
    #423048
    bazza500
    It can be accessed through the bottom front panel. Attached to the left hand side of the sump. Remove the plug connector and release the clip on top and it just pulls out.
    Power off before going in.
    #423049
    RussJH
    Well thanks very much this seems to have done the trick.
    There wasn’t much debris in there, but it was obviously enough to upset it.
    Presumably I was correct in not separating the switch to clean it, it does look like it might come apart fairly easily?
    #423050
    bazza500
    Don’t have to take it apart. Just a flush out does the trick.
    #423051
    RussJH
    Now having another issue with this machine, it’s leaving a small amount of water in the bottom of the machine, just enough to cover the mesh grill. It’s probably only a few cup fulls if that.
    Can anyone help please ?
    #423052
    bazza500
    This machine probably needs the pressure switch modification done.
    #423053
    RussJH
    I will get on to AEG and see if that’s the case, thank you
