Hi – I have an AEG Favorit 55002 dishwasher (pnc 911436014). It’s showing an e20 not draining error. I’ve cleaned the filters. I removed the base and checked/removed the drain pump (which seems to run ok, so I think IS draining) and made sure the hose is completely clear. I cleaned the sensor which had a little bit on gunge on it.
Running it through a 30-min cycle, I saw the countdown timer jump from 8 mins back to 13, it then filled and drained a couple of times like that, before finally clearing the program normally. No e20 error that time. But then next time, back to e20.
Any ideas!? It’s only 2.5 yrs old! Thanks.
