AEG favorit 86011vII heating problem
Home Forums Public Support Forums Help And Support Dishwasher Help Forum AEG favorit 86011vII heating problem
  • #62309
    nigeing
    AEG favorit 86011vII/pcn 911937613/01 not heating up water during any of cycles.Have checked heater element resistance which is 25 ohms.There is a live feed to element but no neutral to make circuit.Is there a thermostat,have looked but can’t seem to find one,how is water temperature regulated?Have had PCB repaired which did have a fault with the heater circuit.Any suggestions would be grateful.Many Thanks all.
    #349602
    Re: AEG favorit 86011vII heating problem
    If you’ve gone that far you should be able to trace the neutral out.
    Although I would suggest that you do so with the power off.
    nigeing
    Hi,have done that,it goes to heater relay on pcb(which has been repaired)thinking is that whatever is controling water temp is not allowing relay to work correctley,but am uable to find temp sensor.How is water temp controled?Many Thanks NC.
    #349604
    Water temperature will be controlled by an NTC mounted around the tank somewhere or beside the heater, can be mounted on the heater. Its resistance is read by the PCB which will then engage or disengage the heater as required.
    nigeing
    Hi,at last problem ressolved faulty NTC.Many thanks to kwatt for his help.
