Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › AEG Favorit 911936627/04 not heating but element is fine
- This topic has 5 replies, 3 voices, and was last updated 12 years, 4 months ago by
j1mt.
November 24, 2013 at 7:55 pm #78294
j1mt
ParticipantLast week we noticed our dishes coming out the dishwasher soaking and not very clean and further investigation showed the water was not heating. I made an assumption that the element must have burnt out and ordered a new one. I took the thing apart yesterday and tested the resistances across the new and old and they were the same (c26 Ohms), leading me to the conclusion that the existing one was in fact ok. I fitted the new anyway and sure enough no difference.
I am domestic heating engineer so used to fault finding on boilers but was very confused by the fact that when connected the element was 240v both sides (unlike an immersion for example), and then noticed the drain pump was the same but when running it was normal (ie no volts) on the blue neutral terminal so am I right in thinking this dishwasher switches on the neutral (not something I have come across on a boiler, hence my surprise!)? I then noticed that the thermostat has all blue wires coming out of it and wondered if there was a connection with the neutral to the heater as this is the next obvious thing that would stop the element from being switched on? If the dishwasher switches on neutral this would seem to rule out some sort of neutral fault on the wiring (though I have had to repair the harness where it comes under the door as some of these wires had worn but this was indicated by a loss of power as you opened the door). I’d be grateful for any tips on further testing that might be worth doing, having spent £30 on a new element I’m keen not to chuck another part at the problem unnecessarily! Thanks in anticipation.
Sent from my iPad using TapatalkNovember 24, 2013 at 8:15 pm #405114Martin
ParticipantRe: AEG Favorit 911936627/04 not heating but element is fine
Take a closer look at the wiring harness under the door. I suspect the heater wire is also broken.
November 24, 2013 at 8:55 pm #405115j1mt
Just rechecked the harness, all the crimp connections I’d had to do on the broken wires (that was about a year ago) are all sound, none of the others have been damaged since.
Sent from my HTC One S using Tapatalk
November 25, 2013 at 11:41 am #405116j1mt
Any further thoughts on this? Could this be a thermostat fault?
November 30, 2013 at 7:36 pm #405117Seamy
PCB more than likely has a faulty heater relay, part number for the board is 973911936627042
December 2, 2013 at 11:17 am #405118j1mt
ParticipantAEG Favorit 911936627/04 not heating but element is fine
Thanks Seamy, much appreciated. I had kind of reluctantly come to that conclusion. Given the cost of the PCB, do you think it might be repairable (is it possible to identify and replace the relay on its own?), would I be better off simply replacing the machine. Not impressed that it has failed so expensively in 4 years!
If the other big manufacturers are no more reliable then maybe the PCB is worth it? What do you think?
Thanks again for the reply, thought it had gone cold!
Sent from my iPad using Tapatalk -
