AEG Favorit Active – Kick Panel removal
Home Forums Public Support Forums Help And Support Dishwasher Help Forum AEG Favorit Active – Kick Panel removal
  • #23679
    brownbear
    Got an AEG Favorit Active AA – pnc 911 232 547 00
    It’s got a leak that’s triggering the aqua control system.
    I’ve cleared the fault by tipping the machine, and need to remove the side panels to find the leak.
    I’ve removed the top and all screws holding the side panels, but I can’t work out how to free them from the front edge.
    From what I can see, it’s either something to do with 2 plastic clips on either side near top of door frame, or a further screw behind the front kick panel.
    Without forcing them, I can’t work out the knack to removing either the clips or the kick-panel.
    Anyone got any tips?
    Oh, and yes I’ve unplugged it!
    Jim
    #198987
    Re: AEG Favorit Active – Side Panel removal
    Two more screws – remove kick panel and you should be able to lift it away.
    brownbear
    OK thanks, I thought I could see the screws, I just can’t work out how to get the kick panel off.
    (without tearing it off or smashing it with a sledgehammer grrr 👿 )
    Also what is the likely cause on this model, is it the filling matrix?
    Jim
    #198989
    brownbear
    Re: AEG Favorit Active – Kick Panel removal
    ^ ttt ^
    #198990
    There should be two screws inset into the front moulding. Either pull the door down and work under it, or remove door outer panel for better access.
