AEG favorit leak
  • #46358
    spuds_own
    our favorit 42300 is leaking from the bottom left hand corner
    i had the machine apart as it was not washing properly i fixed that problem but seem to have created this one could i have disturbed the seal or damaged it?
    any help would be much appreciated
    stew
    #289060
    Re: AEG favorit leak
    From the front of the door, or down the side into the base? If the former it’s possibly the door seals or a split bottom rotor. If the latter, check the seal on the vent from the fill matrix into the cavity.
    spuds_own
    its leaking in the bottom left front corner only when its washing
