If this model has the AUTO setting then check its heating on this setting as i once had an AEG d/w with this symptom and i checked it on the 30 min cycle and it heated everytime but cust called me back about 3 times and in the end i waited for it to heat on the auto setting and it didnt i took it into the workshop so i could spend time on it and it actually turned out to be the main wash pump at fault even though the pump appeared to be working 😯 😯 .Ive since had this twice more so its worth checking
captaincaveman1 wrote:If this model has the AUTO setting then check its heating on this setting as i once had an AEG d/w with this symptom and i checked it on the 30 min cycle and it heated everytime but cust called me back about 3 times and in the end i waited for it to heat on the auto setting and it didnt i took it into the workshop so i could spend time on it and it actually turned out to be the main wash pump at fault even though the pump appeared to be working 😯 😯 .Ive since had this twice more so its worth checking
Interesting…what was happening to the wash pumps then …runing to slow..? or..cutting out…??
yes ive used the quick wash to get it to heat , i will try the other programes and see what happens
