Aeg FSB42607Z integrated dishwasher
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Aeg FSB42607Z integrated dishwasher
  • #103462
    Raovencleaning
    Hi guys, the above dishwasher is stopping mid cycle and not heating up.
    I’ve checked the heater itself and ok, drains ok so working and no blockage,
    wiring looks ok too.
    What am I missing? Is it more likely to be a relay issue not switching the heater on?
    Would appreciate some insight
    Cheers
    Rob
    #493239
    need the pnc number off the label as there are 31 machines to choose from
    but am guessing motor tachometer, depends on the motor fitted
    Raovencleaning
    Thanks for replying Dave, I’ll have to ask the guy for the pnc number…..
    is the tachometer fitted to the motor replaceable? I didn’t think they were.
    cheers Dave
    Rob
    #493241
    Raovencleaning
    Pnc 911535221 (05)
    #493242
    no its a later motor so cant be the fault i thought it might be
    double check heater from the terminals as there is an overheat stat on it
    after that can be
    relays / board
    thermostat
    wash motor
    Raovencleaning
    Brilliant, cheers completely overlooked the thermostat!
    Thanks for your help Dave
    Rob
    #493244
    at 25 degrees c temp sensor reading should be 4850 ohms
    Raovencleaning
    Ok, yes so it’ll decrease as temperature rises
    thanks Dave
    #493246
    Raovencleaning
    It’s a combo with the turbidity sensor, and doesn’t have separate power(2) connections. How can I test it?
    #493247
    the NTC is pin 3 and 4 on the connector
    Raovencleaning
    Thank you very much Dave
    Rob
