AEG fss52615z
  • #101050
    Texpis
    Hi all a bit of help if you can
    I have an AEG dishwasher which occasionally comes up with an i11 Code fault (which is inlet water problem) if I reset it it floods. I have checked the water inlet and the drain and all is fine. I suspect it’s a level problem so I looked for a level pressure switch but there doesn’t appear to be one. Does anyone know how the level is controlled in this type of dishwasher.
    thanks Mick
    #483163
    since there about 10 different units with the same model i need the complete pnc number to find it
    Texpis
    Hi Dave thanks for the reply the
    number is PNC 911 536 303 00
    #483165
    the switch is mounted on the side of the sump
    140000554083 Dishwasher Pressure Switch Sensor (ukwhitegoods.co.uk)
    Texpis
    Hi Dave thanks for the reply, I can’t see a switch on the side of the sump there are 3 outlets one is to or from the salt reservoir, one is the outlet/pump and the other is a turbity sensor. On thing I did notice but at first dismissed it there’s a box on the hose at the tap end and I noticed it was hot, whilst looking now there are to wires go up the hose I guess to this box could it be a flow meter and could it be the problem.
    mick
    on further surfing I see that the box on the inlet pipe is the inlet solenoid. Could it be the solenoid sticks intermittently (hence it getting warm and the i11 fault appears ) then when reset it fills again flooding the machine?
    #483167
    well its there somewhere as parts list shows it for your model
