Customer has complained of numerous i20 and i11 faults but unable to find anything wrong. Whilst testing noticed it got down to 1 min. left then reverted to 10 minuites ???
service number 911434446/04
it is a difficult fault but both these faults have no solid link apart from the board and thats quite a chance to take. i would pull the board and check for domed caps as ac on a dc line can cause all sorts of problems
can send you the service info if you think it would be useful
yes, any info is always useful, Thanks
i had thought pcb but as you say its a bit of a punt, had also thought i should double check earth leakage on heater when hot. Not sure if that might cause issues ??
