I’ve got an old (10+ years) AEG hob, which worked perfectly well until my missus decided to give it a good clean.
After the said procedure has been applied, two of four burners’ piezo ignitions stopped working.
I am unsure of model number as I would need to dismantle the hob but it is visually very similar to this one:
http://www.appliancesdirect.co.uk/AEG_6 … ersion.asp
The ignition is not automatic, the knob needs to be pressed down and kept that way until gas ignites (usually takes 3-4 attempts (piezo ‘clicks’).
The hob is cheap so I guess calling for an engineer doesn’t make financial sense. Is there any spare part/DIY solution available for these?
Many thanks!
