AEG Heater only the TOC required.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries AEG Heater only the TOC required.
  • #102104
    RocketMan
    Ref heater 8581366110329. It’s for a 91609675201/T65270AC condenser dryer
    I’m after the TOC for this heater. I see it’s only available as a complete heater. Not sure what temperature the TOC is sorry.
    Diagnosed remotely as it’s way out of my area but going to do the job as a favour to someone I know.
    I talked them through the test mode and accessed the correct fault code E63.
    Cleared fault code and after running the dryer, it faults and the E63 is again accessed from test mode.
    It could be the heater as he’s just moved but if it’s just the TOC that would be a better option. I will of course go armed with a full heater as well.
    TIA
    #487591
    toc is rivetted to the mica. the chances of drilling steel rivet off mica are close to zero and then try getting rivets back
    you cant buy the stat, complete heater only
    but beware there is a service bulletin about fitting the heater and fitting will need email to send it to you if you want
    RocketMan
    Dave,
    As every, you’re a top man.
    Rivetted TOC. Another step close to making thngs even more difficult and costly to repair.
    Please, if you don’t mind to the TB. If you could email me that would be great. Might need it for my own AEG dryer.
    Right,now to find a reasonably priced heater… 🙁
    #487593
    no probs
    thought i had your email but cant find it
    let me have it again
