AEG HOB DEAD APART FROM AN E CODE
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries AEG HOB DEAD APART FROM AN E CODE
  • #42785
    expertcat
    AEG 78001KF-N
    PRODUCT 949592510
    SERIAL 72546010
    Fault code E3 flashes up as soon as power comes on then all dispalys say E.
    Customer book says E is error code but the 3 I think is more pacific to an area.
    Has any one got ideas as connect list quite a few parts regarding power boards, fan assembly pcb and then modification kits.
    Paul
    #274924
    Seamy
    Re: AEG DEAD APART FROM AN E CODE
    E30s are all related to pressure switch (water level).
    Machine may not have emptied all the water out for instance.
    #274925
    Voltage error – will send you something.
    It’s an induction hob, Seamy……. 😀
    bendaireboy
    Re: AEG HOB DEAD APART FROM AN E CODE
    Seamy could be right some sort of LEAKAGE sorry could’nt resist 😆
    #274927
    mikehha
    as aeg and zanussi are part of the same group I wonder if your e3 fault is the same as mine (posted thursday) so when you find the answer re post it thanks mike (mikehha)
    #274928
    Not the same, Mike. I have sent you something useful…..
