Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › AEG (In) Competence – C41022GM ( Grill & Heating Problem
- This topic has 3 replies, 2 voices, and was last updated 16 years ago by
DaleBoy2.
April 3, 2010 at 9:49 am #53761
DaleBoy2
ParticipantHi All,
I am looking for some help with my Incompetance – C41022GM ! 😉
The Part Number is : 941309738
—— Problem I am Experiencing ————-
1) Both grills either in the main or side oven do not heat correctly as they keep switching themselves off when they come up to temperature. This is very frustrating as it takes 30 minutes to cook a bacon sandwich !!!!! ( other sandwiches are available)
2) Main oven takes 25 minutes to come up to temperature ! Is this normal behaviour ? Can someone please advise if the following part :
Will this Fix The Problem? As making toad in the hole becomes a “whole” evening experience !!!!
Any thoughts or pointers will be really helpful.
Ta
Dale Boy 2 !!!!!!!
😛April 4, 2010 at 3:07 pm #317124Phidom
ParticipantRe: AEG (In) Competence – C41022GM ( Grill & Heating Pro
Presumably you are not hearing the fan working then?
April 8, 2010 at 4:37 pm #317125DaleBoy2
yes the fan works fine…Any other suggestions
April 8, 2010 at 5:25 pm #317126Phidom
The part you mentioned is for controlling the tan that keeps the controls cool when grilling etc. If that part had failed, the fan could fail to come on and the control area could overheat. In such circumstances there would normally be additional protection in the form of a TOC (thermal overload cut-out) which would shut off the heating elements when the fan had failed to keep the control panel cool. This TOC will be a metal cylinder about 1 cm diameter with 2 spade terminals, mounted somewhere on the steel panels of the appliance. I tried to find a part number for this but the part descriptions have been poorly translated from Italian so it’s not easy to identify the right one. It could be part No. 50281190004 but I can’t find a photo of that part so I’m not sure.
