aeg kdwi d/w
  • #12900
    eng14
    went to this d/w 3 weeks ago,cleared out system.started to fill again worked fine then stopped filling again.went to zanussi at maidenhead my mates there told me its ovrfilling and need a conversion kit,which is new valves wiring,tubes etc,is there anyway to repair this without kit as it has worked fine for 5 years they say its overfilling and this will cure it ta for any advice richard.
    #152179
    Dave_Conway
    Re: aeg kdwi d/w
    Fit the IWMS conversion kit 😉
    It solves so many problems 😀
    #152180
    bobokines
    Re: aeg kdwi d/w
    What exactly is this kit and why is it needed? I have seen loads of Zan dishwashers with blockages but I have never been unable to sort them out. Surely the time taken to fit the kit would be the same as to clean out the old one. Or am I missing something?
    Bob
    #152181
    Dave_Conway
    Re: aeg kdwi d/w
    It consists of a new air break, pressure switch, inlet valve etc basically everything to resolve the intermittent no fill problems with these.
    But yes, cleaning them does work quite often.
    #152182
    bobokines
    Re: aeg kdwi d/w
    Is it “One kit fits all”? or are a there several kits. If it is a universal, do you have a part number please.
    Bob
    #152183
    Re: aeg kdwi d/w
    Not sure about all Zanussi models but I had one last week that I cured by cleaning out the gunge, however checking on TDS on this one model reveals two different kits, one for the “New Structure” & one for the “Evolution” type machines, you can tell which is which by looking in the sump/base.
    Model was a DWS909
    #152184
    Re: aeg kdwi d/w
    Dave_Conway wrote:Fit the IWMS conversion kit 😉
    Is this what TDS info calls “The new ATB system” ?
    #152185
    Dave_Conway
    Re: aeg kdwi d/w
    I’m not sure about the “ATB System” to be honest, but I would imagine it’s the same thing. Normally the diagram shows a large bracket enompassing all the above parts.
    There are a few variations as well, PNC is always required to get the right kit.
    #152186
    bobokines
    Re: aeg kdwi d/w
    I like to complete as many calls as I can on the first visit. If there is not a universal kit and cleaning it out clears the problem, then how is it viable to make an incomplete call just to go back with go back with a special kit?
    :con:
    Bob
    #152187
    Dave_Conway
    Re: aeg kdwi d/w
    From experience, I would go once and attempt the clean out job, if it happens again fit the kit on the recall visit 🙂
    #152188
    bobokines
    Re: aeg kdwi d/w
    OK… Are the part numbers available on the TDS disk or do I keep guessing???
    Bob
    #152189
    Dave_Conway
    Re: aeg kdwi d/w
    On the TDS disk Bob, or they should be.
    If not, let me know and I’ll check with Lux directly, I’ll need the PNC though 🙂
