AEG KM8403001M cuts out on micro mode
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries AEG KM8403001M cuts out on micro mode
  • #92727
    don
    Help please?
    PNC 944066040, S/N 42405462
    Works fine on oven and grill, cuts out out on microwave mode only. This can be on first use or on repeat. When it does cut out there appears to be what sounds like a relay clicking.
    We have replaced Magnetron, PCB, capacitor and diode. Have metered door switches which are fine.
    TIA
    Don
    #452001
    Re: AEG KM8403001M cuts out on micro mode
    not an easy fault from the way you describe it
    as far as I know this unit does not monitor the microwave circuit so even if you disconnected transformer primary it should still show the same problem
    not sure if you have tech access but the only thing I could see that might help is attached
    hope you crack it
    don
    Thanks Dave
    I’ll let you know how it goes.
    Don
