AEG L 99695 HWD not drying
Home Forums Public Support Forums Help And Support Washing Machine Help Forum AEG L 99695 HWD not drying
  • #98202
    AndrewE
    I have an AEG washer dryer with a heat pump dryer, and the dryer has never really worked. If you put it on the highest setting (Extra Dry) it will run for a few hours, but clothes etc will still come out damp as if they haven’t really been dried at all.
    This has been an issue the entire time we have had the machine, but have started to want to use the dryer more recently so it has become as issue.
    Does anyone know what might be causing this.
    Andrew
    #471345
    Gokhk
    Might help people if you post a pnc number buddy
    Take a read of the service manual too , im currently having a similar issue but yours is a slight different model and luckily for you the manual is in English. Though your model is a lot more complex with things like a refrigerant so i wouldn’t advise messing with it too much as it may be a sealed system.
    https://elektrotanya.com/aeg_l99695_…wnload.html#dl
    Good luck
