Got a problem with the above W/m, It intermittantly stays locked, sometimes for hours on end, Cust says its mostly O.k on first wash its second load etc that a prob, I’ve fitted a new door lock and now the cust claims its not as frequent but still an issue. should i be thinking PCB?
Or blocked pressure bottle or filter – the analogic pressure switch is very sensitive so it may detect water in the machine and not unlock the door. The pressure switch will not allow the instantaneous door interlock to open if there is water present, even a little bit. Worth a look…….:wink:
