AEG L11842VIT integrated washer dryer
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries AEG L11842VIT integrated washer dryer
  • #84992
    jason1970
    Morning Gents
    I’ve had a look at this machine. It is dead but I have power to the module. It’s an expensive machine and the customer wants it repairing. Before I take the plunge and order a module is there anything else I should look for? I’ve examined the module and I see no flash marks, damage or dry joints etc.
    Thank you for your help!
    #427386
    Re: AEG L11842VIT integrated washer dryer
    had a few of this type of board fail. my veiw is it is because it is integrated and client does not turn it off so board is on most of the time
    look at the board where the power goes in and you will find a resistor. most of the timn its green with a value under 100 ohm. check this resistor. if its blown then it will be the power supply chip which can be fixed
    when you buy a new board make sure its the pre configured one and make sure you check the prod number as there are 12 machines with the same model no
    jason1970
    Hi Dave
    Really appreciate your advice and prompt reply. The machine is in an up-market lodge and guests may leave it on for months!
    Many thanks
    Jason
    #427388
    have had a bit more time
    have check 2 of the machines at random and they both have different boards despite having the same model no
    looked up one on connect and they want £96 plus vat
    i would ring lux trade on 01325 302464 when asked for a trade acct no just push #. you will prob find its cheaper than connect as they inflate prices and they will take a cc no over the phone
    jason1970
    Thanks again Dave
    I used the 914….. number to identify the correct module, which fortunately is pre-programmed!
    I appreciate your help. I’ll let you know the outcome. The job is booked back in for Thursday.
    Cheers
    Jason
    #427390
    jason1970
    Hi Dave
    Finally got back to the job and pleased to say the new module did cure the problem!
    One happy customer and one relieved engineer!
    Thanks again for your help!
    Cheers
    Jason
