Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › AEG L12843VIT (914606107/02)
- This topic has 11 replies, 2 voices, and was last updated 13 years, 1 month ago by
rocker.
February 16, 2013 at 7:18 pm #74172
rocker
Participantwhen machine is set on a heat cycle, it runs for about 15 to 20 then timer jumps to finish. the heater is working ok, also have tested it on spin cycle only, and it will complete cycle.
any pointers please.February 16, 2013 at 9:17 pm #390331Martin
ParticipantRe: AEG L12843VIT (914606107/02)
By “heat cycle” do you mean on tumble dry? Any error codes? If that dryer element has any earth leak greater than 40 meg or if the condenser is blocked the dryer will go faulty.
February 17, 2013 at 8:58 am #390332rocker
Martin, thanks for reply, the problem is on wash cycle, when the wash cycle aborted I checked the water was warming up, no error codes ?
February 17, 2013 at 9:29 am #390333Martin
…..and what are the insulation readings on both the water AND dryers elements?
February 17, 2013 at 11:49 am #390334rocker
will get back to you on that, as I only had a multimeter with me, tested with that. (naughty I know)
I presume the wash element is the same greater than 40 meg,
johnFebruary 17, 2013 at 3:13 pm #390335Martin
rocker wrote:will get back to you on that, as I only had a multimeter with me,
Note to self then……. “Make sure I take my Megger with me on every repair!”😉
February 17, 2013 at 3:47 pm #390336rocker
couldn’t have put it better myself. thanks again
February 17, 2013 at 7:41 pm #390337rocker
Update on this machine, customer has just done a 40 deg cycle wash &
tumble drying cycle. completed no problems
so it seems its only a problem on hot cycle !! confused !!February 17, 2013 at 7:51 pm #390338Martin
rocker wrote:confused !!
Aren’t we both, but we both love a challenge. Next step, out with the Megger, check both elements, resistance reading on water NTC and check through the diagnostics cycle for ‘last error code recorded’ would be the way forward.
A nice first call Monday morning job methinks. :clown:
February 17, 2013 at 8:20 pm #390339rocker
Martin, Will do, but how do I get into diagnostics please.
February 17, 2013 at 8:48 pm #390340Martin
Same as all the ELux stuff, power off, start/pause button, 1st option button etc……. (See Known Error Codes thread if you really have no idea what I’m talking about) or search ‘diagnostics’ as there’s more on the subject than you can shake a stick at! 😀
February 17, 2013 at 9:47 pm #390341rocker
Many thanks for all your help on this Martin. sure I can sort it now. !!
