Hi went to this machine fault no display repalced pcb main and display now will only work for a min then goes on to pause but you can not restart it till you reset it. then it will only do another min then go to pause.
Insulation checks on heater(s) and motor must be below 40Meg
Can also be loose connection somewhere.
Is it filling during that initial 1 min? If so, sounds like fault may be when motor kicks in.
Mike.
