Re: AEG L14710 VIT built in washer dryer
Run the diagnostics to find the stored error code. With the selector set to position 1, press and hold Start / Pause and the next button to the left of it. Switch on. Hold for 5 secs and the LED’s will flash. Turn the selector slowly, one position at a time to fill on the different valves, test heater, drain and spin. The drier is then checked. Continue through to position 10 and the last error code will flash in the display. Fault codes are in the Code book or Known Error codes. To cancel the diagnostic switch off and on again. (You may have to do this twice if EEO appears).
Faults on these are usually door interlock, pump or PCB faults. Although on a 2006 machine, brushes are a possibility.
Steve.
