Aeg L14710 VIT E10 code
  • #74148
    Frase0_1
    Hi my Aeg L14710VIT washes alright but when on dryer tumbles for a short time then displays E10. Up to this point the heater and distribution fan are not activated..Thanks in advance Helen
    #390171
    helo_75
    Re: Aeg L14710 VIT E10 code
    the green valve coil which feeds the condesnser is faulty… plug out if your testing it!
    #390172
    Frase0_1
    Thanks for prompt reply.Would that also stop the heater and fan motor being energised??
    #390173
    helo_75
    it would. it simpy doesnt see the point of carrying on, wasting electricity when it isnt goin to dry.. it does take 3-4 mins for the heater and fan to come on when its working normally anyway,, it tests components before it starts to dry
    good luck
    #390174
    Frase0_1
    Had machine running but both the heater and fan motor fail to start at anytime 🙁
    #390175
    helo_75
    can only tell you whats wrong..
    #390176
    Replace the valve, only then will the fan and heater come on….OK?
    #390177
    Frase0_1
    🙁 replaced valve but still the same.. Any ideas?? Thanks in advance
    #390178
    helo_75
    which valve did you replace?
    next thing is to clean the condenser on the back, its probably full of fluff
    #390179
    Frase0_1
    Condenser clean,that was the first thing I tried 🙁
    #390180
    Frase0_1
    Anyone any ideas?? 🙁
    #390181
    We’re never lost for ideas. Checking the heater element, dryer NTC’s and the main power board should form part of an on-going diagnostic procedure. Check and double check the order of the day……….. “……..to infinity and beyond…!” 😉
