This machine has a problem with the drying cycle, the washing comes out wet and hot on completion of the program. The machine drains OK, the water valve for the condenser is working OK, and the condensing chamber is clear. The fan is working as is the heater as the cloths are hot. Am I missing something with this one or is the cause staring me in the face? All the sump hoses are clear.
Wet and hot in all instances means a water flow problem of some kind. Either the valve is’nt doing its job or it ain’t flowing into the condenser or some such.
I can see the water flowing from the water valve into the condensing chamber? The small chamber to the rear of the soap dispenser is clear and when I take the top off and run the machine water is injected in to the plastic tube that is connected to the condensing chamber.
