AEG L14800 washer drier dead.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries AEG L14800 washer drier dead.
  • #76491
    aqualectric
    AEG L14800 washer drier. PNC 91460151901. Serial no:- 091000150.
    Machine stops in cycle with display dead. Turn off and on again, display back up and seems OK. As a program is being set, some positions on the selector switch make the machine go dead (no display, as if it was switched off). So I fitted a new 24 position selector unit and all seemed well.
    Had a call tonight to say the same problem has occurred. I have had the main PCB out to check for damage, none found. Cleaned connections and refitted. But obviously that didn’t work.
    I have checked the machine for earth faults (all OK) and all looms look perfect; filter clear and machine is working fine on fill, wash, heat, drain and spin. Drier fires up OK as well. I am starting to think PCB main board; but these are usually really reliable, so I am reluctant to order one yet.
    Any ideas?
    Thanks,
    Steve.
    #398503
    Re: AEG L14800 washer drier dead.
    Connection between display and main board maybe?
    #398504
    aqualectric
    Thanks for the reply Martin.
    Went today and checked the machine over. Took control panel of and inspected PCB; took the casing off and checked all components for continuity and earth faults. All OK. All connections sound and clean / tight. Set the selector to a program and control panel lights up. Then turn the selector off then set to another program. Dead…nothing. Turn the power off or unplug and plug in again; program comes up as normal. Will start a cycle and cut out randomly and with no pattern.
    Very strange to spooky… 😕
    I cannot think of anything else but the main PCB as the selector switch is new. I am always wary of blaming the PCB as the Zanussi based machines of this era seemed pretty good in the PCB department.
    Any ideas or things that I have missed?
    Steve.
    #398505
    Well Steve I guess it may be a dodgy cap on the PCB not always opening the power relay or some such technical nonsense I know little about. 🙁
    #398506
    Hollytree_Technical
    More likely to be a dodgy switch mode PSU chip on the main PCB.
    Jem
    #398507
    aqualectric
    Hollytree_Technical wrote:More likely to be a dodgy switch mode PSU chip on the main PCB.
    Jem
    :worthy:
