AEG L14840 914605004/02
  • #89176
    rocker
    Original fault when I first called, turn selector switch sometimes it lite up the timer display or not, but if it was left for a few hours, it could start working anytime…
    Customer ordered a new Pcb.. I fitted it today, when it was first fitted & turned on it worked for a few times, but it appears to have gone back to original problem, I have tested motor & heater for earth leaks both ok. can anyone shed a light as to what may be causing this fault. cheers John
    #440560
    Re: AEG L14840 914605004/02
    Dodgy door interlock plug maybe?
    #440561
    rocker
    cheers martin will check it out. John
    #440562
    bazza500
    This sounds very much like an earth fault on the dryer heater. Try disconnecting it and see if it lights up.
