Hi Guys,
Have this machine (PNC 9146101605)which is giving quite a lot of headache. Machine does not start, the error E40 appears whoch means that the door is not properly locked, changed the door switch, still the same problem. I tried the door switch manually with the screwdriver to eliminate the door itself, still no go.
There is a black pressure guage (apparently it has two) that makes abnormal noise when you turn the machine on.I also changed it but still it makes the noise.
Any ideas would be greatly appreciated.
Regards
