AEG L16810 W/D Help
  • #23022
    Fairdeal
    Hi Guys,
    Have this machine (PNC 9146101605)which is giving quite a lot of headache. Machine does not start, the error E40 appears whoch means that the door is not properly locked, changed the door switch, still the same problem. I tried the door switch manually with the screwdriver to eliminate the door itself, still no go.
    There is a black pressure guage (apparently it has two) that makes abnormal noise when you turn the machine on.I also changed it but still it makes the noise.
    Any ideas would be greatly appreciated.
    Regards
    #196810
    Re: AEG L16810 W/D Help
    Looking on the TDS disk the error code E40 is not listed for a Lavamat 16810. The PNC you gave also doesn’t check out 😕 The nearest I can see is: 91460160501….
    Very confusing 😕
    #196811
    Fairdeal
    Sorry Martin, made the mistake on the PNC, but you got the correct one.Do you have any idea what it could be? that washer dryer is hardly 2 years old and in immaculate condition.That is why I am reluctant to say to them to change it.
    #196812
    cab
    hi if the door lock has been changed it is either a wiring fault or pcb
    cab
    #196813
    Bound to be the PCB (the one at the top that is), had one the other week, clunk clunk is the sound of the door lock. not too expensive on that one though so worth doing. needs configuring though.
    #196814
    Fairdeal
    Guys got another same washer dryer but what happens is that no matter which programme I choose, it goes straight to Drain, and the display shows 3 minutes and then finishes the drain cycle and that is it.
    Does not show any Error Code.
    Any Ideas?
    #196815
    Alanj
    Hi Guys,
    had one recently throwing up variety of faults.
    Turned out to be earth fault at motor.Worth a try.
    Alan
