AEG L16820 facia lights flickering
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries AEG L16820 facia lights flickering
  • #66346
    jenson
    hi,been to this today,when u select a program it comes up briefly flickering an then is blank,no lights at all,the door does lock an i noticed heat on the door interlock,changed that but exactly the same,im thinking pcb”s but has any one found simular problem,cheers
    #363859
    Seamy
    Re: AEG L16820 facia lights flickering
    Most likely the loom to lock & p.c.b has burn’t connections. Worst case scenario p.c.b may need replaced.
    Advise customer to switch off appliance when not in use to prevent cooking the door lock.
