AEG L16830 repeated pump failure
Home Forums Public Support Forums Help And Support Washing Machine Help Forum AEG L16830 repeated pump failure
  • #99107
    jb753
    I have an AEG washer-dryer, model L16830, type P6359599. It has required three replacement drain pumps over the past six months, and has just failed again.
    The symptoms of the fault are similar each time. The washing cycle fails at the rinse stage with error code E20 (corresponding to drainage failure according to the user manual). Sometimes, draining by hand, removing the filter and spinning the blades manually clears the problem, although I have seen no particular obstructions to the pump. Eventually, the pump stops working completely. If I watch the impeller blades on the drain cycle (with no water in the machine), they vibrate a bit but do not turn. Replacing the pump solves the problem… for a while!
    The hoses inside the machine have been checked for blockages, and I snaked the drain hose. The resistance of the pumps before and after the fault develops remains around 250 ohms, but I don’t think this indicates much.
    My current theory is that a fault in the electronics that control the motor is supplying too much current for too long and burning the pump out, but this is only a guess. I’m not too keen on a new PCB, as these are very expensive, but replacing a switch or sensor is realistic if that would fix the problem.
    I would like to ask what the experts think – is this machine salvageable?
    Thanks.
    #475014
    Where are you getting the replacement pumps from?
    #475015
    tubafan
    I’m no expert but the drain pump for that looks like a standard 240V Askoll part that should last for years. Can’t think how the control board could damage it as it’s either powered or not.
    #475016
    jb753
    Thanks for your replies.
    The first two were fitted by a technician (second time for free under guarantee) and I got the third from ebay. They all say ‘Askoll’ on them, which looks to be the correct manufacturer, but I suppose that is not sufficient to verify if they are genuine articles.
    #475017
    Points to dodgy pumps being fitted tbh.
    #475018
    very unusual this
    fit loads of these pumps and seldom have any problems
    something is mechanically jamming these
    do you suffer with high limescale ?
    jb753
    I agree defective pumps would explain the problem, but I’m not confident that paying more for ‘genuine’ parts would fix the problem.
    I am encouraged that it’s probably not the PCB. The water is definitely hard where I am, so that is a possibility. I will pull apart one of the broken pumps tonight and look for signs of limescale or other friction.
    Cheers.
