AEG L16830 w/dryer
  • #61308
    franz
    This wd wont heat on dry. Have cleared condenser – replaced o/c dryer heater , tested both stats on dryer box – is it likely to be one of the ntc’s. Didn’t have time to remove m/c again to test.Does anyone have any thoughts on what else would cause no heat on dry?
    Thanks Franz
    #345627
    Re: AEG L16830 w/dryer
    have you checked pcb for damage if the element had blown
    have emailed info to your repairs@ email address hope it helps
    franz
    Thanks Dave – pcb looks ok – element was o/c but didn’t blow anything
    Franz
