aeg L16830 washer/dryer door interlock problem
Home Forums Public Support Forums Help And Support Washing Machine Help Forum aeg L16830 washer/dryer door interlock problem
  • #75314
    patchitos
    hi….hoping you can help me…the door light remains green during a program even though it is locked. . occasionally it is red but more often green !…E41 is the error code showing when i run the diagnostics test….is it as simple as replacing the door interlock or could it be something more sinister?…hoping you can help….thank you….john
    #394513
    Specialist01269
    Re: aeg L16830 washer/dryer door interlock problem
    Hi: It could be any 1 of the following causing your problem.
    1) Faulty Interlock. 2)Fault in wiring to the Interlock.
    3)Pause start button pressed. 4) Faulty main PCB.
    You would need to do further diagnostic testing with a meter to narrow it down, but 1st check the start pause button has’nt been inadvertently pressed.
    #394514
    patchitos
    ok..thanks….it’s not the pause button…..the machine otherwise functions perfectly…..i started a wash 15mins ago and the door light remained green….looked just now and it is red! at the end of a cycle there is no or little delay before i can open the door ….sometimes the lock can click a few times like it’s trying to lock….is there a way i can test the lock if i remove it? thanks…john
    #394515
    Specialist01269
    Hi John: The only way to properly test the Interlock is with Live testing which is something we don’t encourage or by substitution of a known good or new part. From the description in your second post is certainly sounds as if the Interlock itself is at fault, if you do decide to fit a replacement try looking in the UKWG shop. The interlock for your machine is listed there at quite a good price.
    Andy
    #394516
    patchitos
    ok Andy……I’ll try a replacement and let you know the result in a few days….many thanks for your help….john
    #394517
    Specialist01269
    Your welcome, enjoy your bank holiday.
    Andy
    #394518
    captaincaveman1
    On this model the door will only lock if the water is above a certain level and if the motor is running above a certain speed E41 can be generated simply because you tried to start it without closing the door properly so it doe’s not guarantee you actually have a fault.
    #394519
    Specialist01269
    If you look at his second post, the door light went green & the wash cycle started and ran for a good time before the error showed up. He also points out that there’s no delay before he can open the door at the end of a cycle.
    #394520
    captaincaveman1
    The wash cycle could well run with the green light as it may not have enough water in the drum to activate the lock. The door switch on this model is instantaneous so there is no delay
    #394521
    Specialist01269
    Ok I appreciate that, but would have thought they’d have noticed that they could open the door instantly before now when using the machine.
    #394522
    captaincaveman1
    Specialist01269 wrote:Ok I appreciate that, but would have thought they’d have noticed that they could open the door instantly before now when using the machine.
    Agreed it seem’s strange as long as they havn’t just bought it second hand. Anyway the bank holiday beckons!!!
    #394523
    Specialist01269
    Gotta be fair, I never thought about that. Enjoy your bank holiday, no doubt we’ll find out what happens later in the week.
