AEG L16830 Washer/Dryer filter problem
Home Forums Public Support Forums Help And Support Washing Machine Help Forum AEG L16830 Washer/Dryer filter problem
  • #44004
    DJ-kh
    It seems people are finding it very easy to clean the filter, but for me it turns out to be a complete nightmare!
    Took some time to remove the drain pump filter but finally I got it out (this is the first time))
    Cleaned (it was little and tried to put it back to the machine again
    But it seems stucked and and the end (after seal) is sticking out
    Only top plastic screw cap is spinning but not catching anything…
    I can’t take it out or screw back in properly.
    Please some help me?
    Any idea to how to remove this? or do I have to call an engineer to fix this?
    Thank you
    #279440
    smartin
    Re: AEG L16830 Washer/Dryer filter problem
    as you pulled it out all the fluff and limescale and wotever else that has built up against it has fallen behind it as you pulled it out, its either that or you need to turn it 180 degrees and then try.
    #279441
    DJ-kh
    Thanks for your quick response, smartin.
    I’ve already tried 360! or even more!!! but it just keeps turing around and around….
    It seems to get loose and then tight and its loose again and again…
    #279442
    smartin
    if you look carefully at the sides of the filter there are 2 raised spines on 1 side and 1 on the other, they locate into grooves in the housing, if they are blocked with limescale it will be difficult to fit and it will only go in 1 way.
