AEG L64840 914524535
  • #77318
    ChrisR
    Hi Guys.
    Machine pumps continually.
    Have checked anti flood etc but all seems well.
    Customer said it stuck on 1 minute until she turned it off.
    She went on holiday and on her return machine stuck in pump mode.
    Any suggestions.
    Thanks.
    Re: AEG L64840 914524535
    Best you go into diagnostics and read the position 10 ‘last error recorded’ I would suggest.
    #401742
    ChrisR
    Thanks Martin.
    How do I do that?.
    #401743
    ChrisR wrote:How do I do that?.
    Same as all the other Lux machines, Press and hold Start and First Option buttons then rotate knob to 1st position until LED’s flash. Release buttons and rotate knob to the 10th position to read off the last error code recorded. Don’t you have TDS then or what? 😀
    #401744
    ChrisR
    No mate I don’t
    #401745
    Seamy
    Disconnect the pipe off pressure switch see if it zeros itself.
    Have found interlocks on these to cause the 1 minute left thouh, by not releasing.
    If pump running maybe theres something stuck in impellor & machine has’nt emptied, if it does’nt read empty it won’t do anything else.
    #401746
    ChrisR
    Thanks Seamy
