AEG L76689 Update
  • #35760
    bigkid
    Hi All,
    When a prog is started on the above (PNC 91400245400) the pump comes on for a few seconds then aborts.
    Albeit a Zanussi and am familiar with the test procedure and error codes I am not with this one.
    Any help would be apreciated.
    Tony
    #247982
    Re: AEG L76689 Update
    Sent you something.
    bigkid
    Thanks Chris, IM or email? nothing in either yet……….
    #247984
    Ah – returned – user unknown. Send me a valid eMail addy and I’ll try again.
    Re-sent.
    C.
    #247986
    bigkid
    Thanks for the info Chris, on returning to the machine EC34 found.
    “Incongruence” between Pressure switch and sensor………
    Are these sensors a problem? or do you recon its more likely a pcb fault?
    Tony
    #247987
    Flyman
    Check the element for an earth fault. This will give you an E34 😕
    If that is ok then it is normally the electronic pressure sensor not the pcb. Unfortunately no simple way of testing them.
    #247988
    Kirk
    Went to one today blockage in pressure system.
    #247989
    bigkid
    Thanks Guys, will keep you posted……….
    #247990
    bigkid
    Update, thanks all turned out to be the pressostat, replaced, no further problems.
    Tx again.
    Tony
