aeg l76800. flashing lights
  • #21673
    PINKY
    In need of some help..AEG l76800 pnc 914003087/00.
    Called to this m/c today.All it does when you select any program is flash the leds.Each postion on the selector causes different leds to flash.You cannot acess the test progam and it does not lock the door.
    Checked the obvious.No earth faults,motor and element all read ok.Nothing obvious wrong with the pcb.No water damage or evidence of rodents.
    Guessing its a pcb fault but it has three.Any ideas???
    Cheers…….PINKY
    #192120
    Dave_Conway
    Re: aeg l76800. flasing lights
    PINKY wrote:Any ideas???
    Door interlock maybe ?
    #192121
    I will start whith rotary switch and its cable to front board electronic. After that, if isn’t work, I would try another user interface PCB.
