AEG L87695WD. 914605701
  • #92714
    ChrisR
    Good afternoon.
    This washer dryer completes the wash programme ok but when used on tumble dry runs for 7 or 8 minutes then stops.
    There’s no fault code.
    When first started on tumble dry,the fan and heaters appear not to function but the condenser water valve is operating.
    I didn’t wait any longer as I’m fairly sure it’s a board problem but any suggestions would be appreciated.
    Re: AEG L87695WD. 914605701
    it goes through a self check procedure before it starts the fan etc
    assume the valve is operating and water is flowing down the tube to the condenser
    also check sensor in the lower hose leading out from the condenser. sometimes the wires snap
    ChrisR
    Thanks Dave.
    Water is flowing.
    I’ll check the sensor wiring.
    #451957
    hi Chris
    did some checking on this one again and the build on this one is new to me. Some of them can use a compressor to provide dryer heat instead of an element so its quite a complex machine
    have picked the info available that may help you and sent you 2 pm’s
    ChrisR
    Second manual not attached Dave
    #451959
    Hi Chris
    just checked and you correct. tried again but it wont send as file is just over 9 megs
    if you pm your email add will see if my email will allow as an attachment
    ChrisR
    Hi Dave.
    Email as below.
    chrisready@yahoo.co.uk.
    Thanks again for your help.
    done
    ChrisR
    Thanks Dave.
    It’s arrived.
