AEG Lav 86720 update Motor replacement .
Home Forums Public Support Forums Help And Support Washing Machine Help Forum AEG Lav 86720 update Motor replacement .
  • #80946
    ishine7909
    I am worried to replace the blown motor.
    I do not want to sacrifice a new motor and want to be as sure as possible that the motor drive electrics PCB or PCB control were OK before replacing the motor.
    The electrics on these machines are usually very solid but do you know if a pcb is always taken out if the motor goes on this model?
    Thank you in advance.
    #414910
    Re: AEG Lav 86720 update Motor replacement .
    You can never be certain of anything when a motor has “blown” but one must assume the worst and expect in so doing the circuit board has also suffered damage.
    The prognosis from where I’m standing therefore ain’t good my friend. 🙁
    #414911
    ishine7909
    Thank you, I will pull out the two PCB’s from the rear bottom right and inspect them first.
