AEG Lav6205W Auto – Disp Hose Fitting
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries AEG Lav6205W Auto – Disp Hose Fitting
  • #43768
    MickGeorge
    Hi Folks
    M/c about 10 years old, orig AGE type (not Zan).
    Went to this and dispenser hose leaking where it fits to dispenser – have order new hose and got to go back and fit it but looked a bit of a pig to fit as no room to get hands in.
    Looks like the hose lips into both dispenser and tub – no clips just looks like a retaining ring that pushes into dispenser end to keep hose secure.
    Is there an easy way to fit this – looks like dispenser out job but not sure?which end of hose is best to fit last?
    Any help/guidence appreciated..
    Mick
    #278505
    Re: AEG Lav6205W Auto – Disp Hose Fitting
    not a lot of room but usually on old aeg machines the front comes off easily giving access from both sides
    Once you remove the control panel fascia and front cabinet panel access from front ain’t too bad. 😉
    #278507
    MickGeorge
    Thanks for the replies guys – not had to have facia or front panel off on these models before (to be honest not had to do many jobs on these models at all).
    Presume facia and front panel straight forward then – no hidden screws or tabs then ? 😉
    Mick
    #278508
    MickGeorge wrote:Presume facia and front panel straight forward then – no hidden screws or tabs then ? 😉
    Very straightforward. Removed dispenser drawer and attaching screws behind, two screws on l/h/side then lift away fascia. The rest is quite obvious….. 🙂
    #278509
    MickGeorge
    Thanks Martin
    The help appreciated. 😀
    Mick
    #278510
    goosegreen
    I did one recently and Found it easier to remove the top of the box.
    Goose
    #278511
    MickGeorge
    Done today
    Removed Facia and rear facia panel – found easier to remove top of dispenser and place to one side as goose sugested. Once that is off you can access the insert that keeps the hose in the dispenser (which I found a pain to get out) remove the bottom half of dispenser which then allows easy access to the clip that holds the hose onto the tub.
    Fitting the new hose it was then easy – just reverse proceedure.
    Did remove the front panel as well but think it may have been possible to do without it’s removal or the facia thinking about it.
    The most compicated dispenser hose I have ever fitted (took about an hour) but not to bad if I had to do again using the above method.
    Thanks for he help and suggestions
    Mick
